Home » Sponsored » Pi Speakers » Let's try those 2Pi Towere pictures again.
Re: Internal displacement [message #39834 is a reply to message #39833] Fri, 10 January 2003 13:37 Go to previous messageGo to previous message
wasteh202 is currently offline  wasteh202
Wayne, if I may butt in here. If you look at the pictures closly you will notice that all the corners where the plywood meets (both vertical and horizontal) have 2x2 bracing. I used the 2x2's to screw and glue the plywood to. I also threw in a couple in back to give the front back braces something to affix to so I could put the back in place when all finished.
I actually calculate the total 2x2 + 1x2 volume to be almost 500 cubic inches so it does add up in my box. I still don't know that it will make a significant difference but I would try to account for it if I were you Eric, just don't get carried away like I did.
Previous Topic: Woofer-tweeter
Next Topic: Active filters
Current Time: Mon Nov 02 01:12:30 CST 2026
