Home » Sponsored » Pi Speakers » Really breaking the rules! Altec Model 19 specs?
This might help [message #39807 is a reply to message #39804] Thu, 09 January 2003 17:25 Go to previous message
Robert Hamel is currently offline  Robert Hamel
I have a short cut to the lansing site brochure
http://www.lansingheritage.org/images/altec/specs/home-systems/model-19/page1.jpg
When I built my XPL 200'S I wanted to maintain the original driver spacing so I scalled it from a photo. What you can do is use a picture editor too take a know dimension in pixels and use that to determine the unknown. If you knew the woofer diameter it would be easy using the brocures to figure out the height of the lower box. You already have the width and depth. Then you can calculate the volume to see if that make more sense.
Just in case you didn't already think of doing this.
Good luck
Previous Topic: Any known issues with Eminence APT super-tweeters?
Next Topic: 16 Ohm crossover
Current Time: Mon Nov 02 13:33:42 CST 2026
