Home » Sponsored » Pi Speakers » 4Pi Pro questions for Wayne, et al
Complex reactive/resistive loads [message #39790 is a reply to message #39789] Wed, 08 January 2003 11:52 Go to previous messageGo to previous message
One must either measure or model the circuit pretty accurately to know what to expect here. To calculate response requires making a virtual circuit of the Altec horn (including the compression driver). In the old days, the best way was to plot a bunch of points by hand, but nowdays it's much easier to do with computers using a program like Spice.
You may be surprised at the response curves given when a filter is in the presence of reactive loads. A purely resistive load will provide damping for the filter to provide the smooth rolloff you expect. But a complex load having both resistive and reactive components will modify the filter pretty substantially. And the loudspeaker itself is a complex load, which the compensation circuit modifies. The bottom line is that the loudspeaker is an integral part of the filter circuit, and all components are inter-related. So you'll need to analyze the circuit in more detail to know its response.
Previous Topic: 4 pi & 7 pi
Next Topic: Any known issues with Eminence APT super-tweeters?
Current Time: Mon Nov 02 11:08:13 CST 2026
