Home » Sponsored » Pi Speakers » 2 pi towers - wiring question
Re: 2 pi towers - wiring question [message #39742 is a reply to message #39732] Sun, 05 January 2003 16:31 Go to previous messageGo to previous message
There should be nothing wrong with attaching the wire to the back wall, as long as you make sure there's still enough 'free' wire hanging from behind the driver(s) so you can get them out of the box if you need to. You may wan't to gain access to the interior of the box in the future to experiment with damping, change drivers, whatever. Also remember to do the same at the terminal end(!)
Previous Topic: Cornerhorn away from corner
Next Topic: New Participant
Current Time: Sat Nov 07 04:11:09 CST 2026
