Home » Sponsored » Pi Speakers » High output compression drivers
Re: High output compression drivers [message #39469 is a reply to message #39465] Fri, 13 December 2002 21:43 Go to previous messageGo to previous message
My favorite compression drivers are the JBL 2426 and the Eminence PSD2002. The TAD 2001 is nice too, but it's expensive. There are lots of other alternatives, but some of them are just too peaky or lack top-octave extension for my taste. As you've noticed, these are all 1" exit drivers. I don't care much for the larger ones.
My experience has been that you either run a 1" exit device or forget about the top octave. Compression horns having 2" exit use 4" diameter diaphragms, so there's a lot of mass to throw around and a large area to try to limit path length distances across. There's 1.4" stuff that has a 3" diaphragm, which might be a good compromise except that it's rare. And there are other sizes too, but the common standards are for 1" and 2" throats. One exception is the TAD 4001 compression driver, which sounds real nice all the way up. But it's over $1000.00 too.
Previous Topic: Plans for 2 Pi Tower
Next Topic: corner horns
Current Time: Sat Oct 17 15:22:00 CDT 2026
