Home » Sponsored » Pi Speakers » JBL E-130/E-140 help
Re: JBL E-130/E-140 help [message #39381 is a reply to message #39378] Sat, 07 December 2002 06:08 Go to previous messageGo to previous message
Something else to keep in mind with sound reinforcement is to use the BIGGEST amps you can find, 2x power rating of drivers isn't out of line. You never want to allow your amps to clip running at the power levels you will be using, much better to let the drivers see too much power than not enough with a bunch of distortion in the signal, sure fire way to fry a speaker.Ideally you want an amp that is big enough that it's basically idling the whole time , nice clean signal. JBLPro.com has some good tech articles about PA aplications.
Kelly
Previous Topic: Hey Wayne Beyma 12cx in 6 Pi?
Next Topic: SET's at MAF in Lima, Ohio
Current Time: Wed Oct 21 05:05:45 CDT 2026
