Home » Sponsored » Pi Speakers » best horn for 2426h in Pi type system?
Final thoughts [message #39224 is a reply to message #39220] Tue, 26 November 2002 05:52 Go to previous messageGo to previous message
D Kurfman is currently offline  D Kurfman
Thanks Tom!
I thought that was what you were implying. The old "self equalizing" horn concept, which is part of what reduces the need for eq on the 2370 and was a characteristic of much of the Klipsch stuff. While I do like much of the CD stuff, particularly the JBL 2344 cheeks, I really don't like it for up close, in your face, listening. I think the issue is the narrow slot normally used to maintain hi-frequency response on one axis. This still basically comes down to a diffraction horn and never sounds as open and effortless as I would like. A 2426, or similar horn, without the need for a bunch of hi-frequency shaping would certainly make things simpler, while at the same time opening up additional options for bi-amping.
Thanks for your thoughts!
Dan
Previous Topic: foreplay freaks look out!
Next Topic: 2Pi cabinet questions
Current Time: Tue Nov 24 15:34:12 CST 2026
