Home » Sponsored » Pi Speakers » Wayne, compensation question please
Re: Wayne, compensation question please [message #39033 is a reply to message #39032] Wed, 13 November 2002 00:17 Go to previous messageGo to previous message
You've assessed the situation pretty accurately - The Peavey CH-3 has a little less in the bottom octave than the 2370. But they're really more similar than you might expect, particularly if a person uses them above 1.6kHz. For the octave below that, the slightly larger size of the 2370 gives a bit more energy and prevents it from being as peaky as smaller horns.
One thing that differentiates the 2370 from the horns I like to use is that it's the only one with a secondary acoustic device in addition to the horn flare. The 2370 has a diffraction slot to increase horizontal dispersion at the highest frequencies. It creates wider dispersion at the expense of an added internal reflection, which causes a slight bit of impedance and response ripple. That's the cause of its "splashy" sound.
Previous Topic: La Scala/10 Pi
Next Topic: SAF
Current Time: Tue Oct 20 23:10:46 CDT 2026
