Home » Sponsored » Pi Speakers » New specs on eminence drivers?
New specs on eminence drivers [message #39008 is a reply to message #39002] Mon, 11 November 2002 11:45 Go to previous messageGo to previous message
You're right, Eminence has changed their specifications. They've procured more accurate measurement systems and they've updated their data. They've built a new measurement chamber and installed a Klippel measurement system, which is the best in the industry.
Eminence has also changed their drivers, so it isn't just the measurements that are different. They have maintained compatibility with earlier models, but they have made improvements that increase power handling. The voice coil manufacturing process has been changed, and so the new drivers are different drivers. Three models of the π Speaker line needed a slight redesign as a result.
The difficult part is knowing which particular motor you have, since there is no part number change to identify it. I think it's a safe assumption that if it has the old label and spec sheet, then it's the old part.
Previous Topic: pi's and tubes, why different than sand?
Next Topic: new selenium compression driver: D3300TI
Current Time: Sat Oct 17 00:39:28 CDT 2026
