Home » Sponsored » Pi Speakers » Variation on a 2pi theme
Actually, it's a three π [message #38739 is a reply to message #38737] Sat, 19 October 2002 17:22 Go to previous messageGo to previous message
What you are describing is essentially a three π speaker. For example, a Thermionic Series three π uses an Alpha 12 and a PSD2002 in a 6 cubic foot box, tuned to 25Hz. A Theater Series three π is similar, but uses a Delta 12LF and a PSD2002.
With each different model woofer, the box is tuned differently, appropriate for the motor's characteristics. If you use the Alpha 12, the box will need to be at least 5 cubic feet. So the cabinet size of the tower two would work pretty well, but the cabinet should be tuned a little lower. PiAlign recommends 5 cubic feet, which should be considered a minimum volume for that particular woofer. Other motors will have their own unique requirements for motor chamber, so it is best to match the woofer with an appropriate box. But it's pretty easy to do, and I think you'll be very pleased with your results.
The system you've described sounds nice, and if you need any of the parts, we have all of them in stock. We have everything available from the midwoofers and compression tweeters to the horn flares and crossovers. You might find it easiest to purchase a three π kit in the "π Speaker Kits" section rather than to order parts individually.
Previous Topic: Eclipse TiPro 18" PICS!!!
Next Topic: Wayne: Refinements for Tower 2 Pi - Good or Bad?
Current Time: Thu Nov 19 09:48:32 CST 2026
