Home » Sponsored » Pi Speakers » Building 2pi Towers - COMPLETE!
Re: Building 2pi Towers - COMPLETE! [message #38707 is a reply to message #38703] Fri, 18 October 2002 06:48 Go to previous messageGo to previous message
Fresno is currently offline  Fresno
>>Do you have a raised hardwood floor, on a second floor or are you
>>on a concrete slab?
I am in a finished basement with a w/w rug on the concrete. 26' x 19'. The front and back walls are panelling an ich or two away from concrete. The side walls are panelling with rooms on the other side.
>>Do you have anything else you can compare with - A different amp,
>>for example?
I hooked them up to my sand amp, SONY STR-DE935, the bass is a bit better. Being able to crank them up louder, I noticed that there was very 'excursion' of the woofer until very high loadness. By excursion I am referring to being able to see the cone move enough to move in and out at the ripples on the outer edge of the cones.
>>Same question on the speakers, are they bass-shy on the same amp,
>>different amps and/or in different rooms?
Not able to test this out yet, won't be able to test different rooms.
Would you like to swing by this weekend and check things out? ;)
Previous Topic: Horns Length, Frequency Wave Lengths, And, All That Good Stuff
Next Topic: How long would a 2-3/4" diameter port be for Studio 2pi?
Current Time: Thu Nov 19 09:09:29 CST 2026
