Home » Sponsored » Pi Speakers » delta 12LF goes high enough?
Re: delta 12LF goes high enough? [message #38503 is a reply to message #38502] Mon, 30 September 2002 13:42 Go to previous messageGo to previous message
bqc is currently offline  bqc
Thanks Wayne
So you are saying the Delta 12LF is an exception to the rule that
LF driver dont perform well at higher frequencies? Which means that
it would do ok?
I heard people talked about driver break up mode and how it is unpleasant
to listen to. Does driver break up mode usually happen at the
high end of its frequency range? If so then how can one
use the the Alpha 10 in the Studio 2pi's all the way up to its upper range without hearing any of the break up mode?
Previous Topic: 4Pi Pro crossover
Next Topic: Wayne: Best Pi for Decware Zen Amp?
Current Time: Sat Oct 17 08:31:39 CDT 2026
