Home » Sponsored » Pi Speakers » Will mounted 2426 fit through horn hole?
the psd-2002 fits thru the opening [message #38487 is a reply to message #38485] Sun, 29 September 2002 16:38 Go to previous message
required by the H-290 easily, even when mounted on the horn already. And the 2426 is only another 1/4 inch larger in diameter, it should fit when put thru at an angle. Sam
Previous Topic: THEATRE 4 Plans
Next Topic: 4Pi Pro crossover
Current Time: Wed Nov 04 17:59:32 CST 2026
