Home » Sponsored » Pi Speakers » Will mounted 2426 fit through horn hole?
Will mounted 2426 fit through horn hole? [message #38482] Sun, 29 September 2002 04:56 Go to previous message
laoye is currently offline  laoye
Hi Wayne,
Thanks so much for all your help in my project!
Will the 2426 mounted on the H290 flare fit through the flare hole on the PI-4 pro? It looks like it should go in if it enters from the front at an an angle, but it will be tight.
If it won't fit in that way, then I need to mount the assembly before sealing the front of the box on. There's no way I'll be able to mount the driver on the flare once it's in the box since the back will be sealed as well. What do you recommend in that case?
Thanks!
- Ken
Previous Topic: THEATRE 4 Plans
Next Topic: 4Pi Pro crossover
Current Time: Wed Nov 04 14:33:04 CST 2026
