Home » Sponsored » Pi Speakers » Insulating subwoofers
Re: Insulating subwoofers [message #38468 is a reply to message #38466] Fri, 27 September 2002 15:06 Go to previous message
I generally recommend that R-13 be installed on the back, bottom and one side. Unless the cabinet is very small, I would not trim the insulation to make it thinner, except do remove the vapor barrier, if present. Position of absorbent material is important and its spacing from the boudary in particular. An absorbant material is most effective when placed at least 1/4 wavelength away from the boundary, and this must be balanced with the issue of viscocity change from having a lot of damping material in the cabinet.
Previous Topic: One Pi's are finished!
Next Topic: SPICE and Piezo Questions
Current Time: Wed Oct 21 22:36:53 CDT 2026
