Home » Sponsored » Pi Speakers » Question for Till E and or Wayne; What next?
4 Pi - Pro with 3677 cab and horn with 2226J's [message #38435 is a reply to message #38434] Wed, 25 September 2002 06:23 Go to previous messageGo to previous message
spkrman57
Till E.
I have done same project. Did you use 1.4 mh coild for 2226J?? I had some 2 mh coils on hand that I used. Did you remove the foam from the ports also??? I used 15 ohm parallel and 30 ohm series attenuation on the horn with .47 ufd compensation. The .33 ufd probably works better on the JBL 2425 or 2426 driver, but I think the 2418 is cheapened version and has less top end. With a mild 30hz eq thrown in they sound great. Let me know how you have implemented yours. I am running off of Marantz 2238B right now, but best sound came from 2215B. I too have had the 2A3 Paramours hooked up with mine. While they sounded good, the Altec A7-500's blew them away. I must say though, the Altecs work best with the flea powered units and don't like the wattage that JBL 2226's like to run in their best environment.
Thanks, Ron
Previous Topic: Predicting room boundary reinforcement
Next Topic: crossover need help badly
Current Time: Fri Nov 20 14:52:55 CST 2026
