Home » Sponsored » Pi Speakers » Horn Loading
Re: Horn Loading [message #38380 is a reply to message #38377] Fri, 20 September 2002 11:23 Go to previous messageGo to previous message
You are right in your assumptions that a horn cannot perform below a frequency determined by its dimensions. And for that reason, bass horns are ineffective unless they are quite large. In many situations, the size requirements make a basshorn untenable. But the Altec VOTT is not a basshorn. It uses a midrange horn and a tweeter horn, and bass output comes from direct radiation using a bass-reflex cabinet.
Previous Topic: Pi Hometheatre System
Next Topic: 2pi port length in larger cabinet?
Current Time: Mon Oct 12 10:24:36 CDT 2026
