Home » Sponsored » Pi Speakers » Help! I'm looking for crossover suggestions for JBL 2445/2446 compression drivers!
Help! I'm looking for crossover suggestions for JBL 2445/2446 compression drivers! [message #38369] Thu, 19 September 2002 07:01 Go to previous message
Mikey is currently offline  Mikey
Hi everyone!
I'm starting to research my winter loudspeaker project, and I've decided on a two-way high efficiency design. The woofer will be a 15" unit (TBD), and the compression driver will be a JBL 2445H/J or 2446H/J, most likely mated to a JBL 2380 or 2382 horn.
I'd like to cross the system at 500-600 Hz, and I'm looking for suggestions for a passive crossover for this compression driver / horn combo. I realize I will have to apply some EQ to obtain flat response up to 20KHz.
So my questions are:
Are there any commercial JBL products which utilize this driver / horn combination at this crossover frequency?
If so, where can I obtain the schematic for the crossover?
If not, has anyone [ Wayne, this means you :-) ] got any ideas where I could start with this design?
Thanks in advance,
Mikey
Previous Topic: Is They Is Or Is They Ain't Horns
Next Topic: Two Pi inductors
Current Time: Thu Nov 26 09:26:00 CST 2026
