Home » Audio » General » Bleeder Resistors
Re: Bleeder Resistors [message #3836 is a reply to message #3835] Tue, 17 October 2006 09:30 Go to previous message
Those look like the clips often used on oscilloscope and multimeters. Should work pretty well. One thing to think about though: If the voltage is high so that there is a bit of arcing as the connection is made, the clip leads might erode over time. There's not a lot of meat on clips like this. Alligator clips are more sizeable, but then again, that means it would be harder to get them connected in tight spaces.
Previous Topic: Wayne, have you been hacking?
Next Topic: Need info about locating a Twin-Coupled tube amp--kit or?
Current Time: Tue Nov 24 19:20:44 CST 2026
