Home » Sponsored » Pi Speakers » alpha 10A frequency response
since you mentioned Qes and R [message #38357 is a reply to message #38353] Wed, 18 September 2002 18:44 Go to previous messageGo to previous message
I thought I would ask about how significant that 0.5 ohm dcr might be. My sansui 5000a has a damping switch on the rear. The two settings give either 50 or 15 for the Df using an 8 ohm load. And all the switch really does is...tada!, add a 0.3 ohm resistor in line with the speaker output.
Maybe because the output is via a bigasscap(2200uF), but these specs show that 0.3 ohms added resistance cuts the Df in this instance by 2/3's. Doesn't that represent a reduction in the amps ability to control the motor? Sam
Previous Topic: Studio 1 pi plans
Next Topic: Is They Is Or Is They Ain't Horns
Current Time: Thu Nov 26 09:33:36 CST 2026
