Home » Sponsored » Pi Speakers » Is They Is Or Is They Ain't Horns
Re: Biggest horns you can fit in a room. [message #38325 is a reply to message #38324] Tue, 17 September 2002 20:22 Go to previous messageGo to previous message
A horn is a device having an entrance (throat), passageway (flare) and exit (mouth). So horns are made by bringing a megaphone-like device in near proximity to loudspeaker diaphragm. The system is usually sealed so the radiated sound has to pass through the horn with no leaks. In the case of the π cornerhorn, the horn for the woofer is formed by the walls of the listening room, itself.
Previous Topic: alpha 10A frequency response
Next Topic: Help! I'm looking for crossover suggestions for JBL 2445/2446 compression drivers!
Current Time: Thu Nov 26 09:34:32 CST 2026
