Home » Sponsored » Pi Speakers » 2 Pi Towers
Re: 2 Pi Towers [message #38280 is a reply to message #38279] Thu, 12 September 2002 20:53 Go to previous messageGo to previous message
Your bracing sounds like a good idea. About the dimensions, it probably will work well as long as you don't change them a lot and you keep the internal volume the same. Don't change where the port is in relation to the bottom of the cabinet and to the woofer. You can modify cabinet dimensions a little bit, but it is particularly important that the port not be at the very end of the box.
As for decals, most are black but I have a few in silver and a few in gold. I use the silver logos on black cabinets, and I'd be happy to send a pair if you'll kindly refresh my memory with your mailing address. Just drop me a line via E-Mail.
Previous Topic: 2pi towers
Next Topic: 8 ohm & 4 ohm
Current Time: Fri Nov 13 19:45:50 CST 2026
