Home » Sponsored » Pi Speakers » Horn - install in cabinet or not?
you can try glueing [message #38199 is a reply to message #38197] Thu, 05 September 2002 18:06 Go to previous messageGo to previous message
1x2's around the inside edge. I repaired an old AR2 speaker that way, for the same reason...the t-nuts were coming loose where the TOO THIN plywood edge crumbled. Alternative to flush mounting is build up the front baffle, cork panels work well, even another layer of brich ply or mdf, with holes to clear the woofer and horn flanges. Very strong. Sam
Previous Topic: Sub-Woofer cabinet
Next Topic: OT: How I Spent My Summer, by......
Current Time: Thu Oct 29 06:25:55 CDT 2026
