Home » Sponsored » Pi Speakers » Horn - install in cabinet or not?
One more thing...actually 2 [message #38197 is a reply to message #38196] Thu, 05 September 2002 16:23 Go to previous messageGo to previous message
Thx for the speedy response (that's one). Also I would consider doubling up the MDF on the baffle or use 1" material as it's going to be a little thin if you flush the horn all the way in. As far as the appearance thing...I think it's the fact that the port is flush with the baffle that makes the horn flange look out of place standing proud as it were...I'll let you know once I hog it out.
Kelly
THX again
Previous Topic: Sub-Woofer cabinet
Next Topic: OT: How I Spent My Summer, by......
Current Time: Thu Oct 29 06:25:55 CDT 2026
