Home » Sponsored » Pi Speakers » corner horn placement
Cornerhorn angles, dispersion and stuff [message #38053 is a reply to message #38050] Mon, 26 August 2002 00:13 Go to previous message
There is no reason you can't rotate the horns from their natural 45° orientation. It is sometimes the best thing to do in rooms that are very long and narrow. But one of the main features of the π cornerhorn is matched angular coverage of each subsystem. When the horns are pointed the same way, each shares the same 90° pattern and coverage is equal. This ensures that the reverberent field is uniform and sound through the room is even.
Previous Topic: Are the 2Pi symmetrical or identical?
Next Topic: DIY recording at concerts - slightly OT ramble
Current Time: Fri Nov 13 09:22:21 CST 2026
