Home » Sponsored » Pi Speakers » Active X user's, system set up
Re: you guys are why the rat bike still needs rubber [message #37987 is a reply to message #37985] Thu, 22 August 2002 13:43 Go to previous messageGo to previous message
Hi Sam,
I read a review on this from Thorston. He indicated that it was Very transparent. All in all it was a very good review for it. the review is online you should check it out.
I notice a little bit of noise from it in my system. I have also heard that in some cases the Ultravurve has some impedance issues with home audio. It is much more transparent when you uses balanced lines. I couldnt plug into it with balanced.
I havnt given up on the idea of using it. but right now I'm still aquiring amps so I'm trying to keep interconnects to a minimum right now.
As far as transparency goes while its in the system. The difference between just being turned on, and switching it to EQ mode with a flat plot is None! You cant tell any difference from switching the EQ off, or on with a flat setting.
Bill
Previous Topic: JBL EBS alignment?????
Next Topic: Tweaking speaker cabinet size
Current Time: Fri Nov 06 05:56:36 CST 2026
