Home » Sponsored » Pi Speakers » 2nd ordrer Butterworth vs 3rd order Butterworth
Re: 2nd ordrer Butterworth vs 3rd order Butterworth [message #37937 is a reply to message #37923] Wed, 21 August 2002 11:33 Go to previous message
The values of R1 and R2 are usually the same when following a second order or third order of the same crossover frequency. But you might want to confirm this with Spice, because while I found it to be true on many of the circuits I tried, I would not assume that is always the case.
About the JBL 2226J (16 ohm version), Le=3.5mH and Re=12.0 ohms. Zobels are pretty wide tolerance filters, meaning component value shifts have a fairly small impact. I would suggest Zobel resistance of 16 ohms and capacitance of 8uF to 15uF.
Previous Topic: 2 Pi Piezo Tweeter Choices
Next Topic: eminence psd-2002 vs selenium d300ti
Current Time: Wed Oct 21 00:30:31 CDT 2026
