Home » Sponsored » Pi Speakers » 2nd ordrer Butterworth vs 3rd order Butterworth
Re: only UNCUT 511B's ring [message #37929 is a reply to message #37927] Wed, 21 August 2002 10:25 Go to previous messageGo to previous message
spkrman57
Sam,
I had noticed after posting about the 3 db loss compared to the 2226H. Yes, you are correct, but this situation will be using a 16ohm horn driver also, so ref wattage will be same, 97db and 115db. Since this product when completed if it works as well as I hope for will be run off P-P tube amp (maybe my Mc240 at 40 watts/chnl on 16 ohm tap. As a bonus, using 16 ohm drivers can use 18 guage wire with less signal loss. Regards, Ron
Previous Topic: 2 Pi Piezo Tweeter Choices
Next Topic: eminence psd-2002 vs selenium d300ti
Current Time: Wed Oct 21 00:30:29 CDT 2026
