Home » Sponsored » Pi Speakers » 2nd ordrer Butterworth vs 3rd order Butterworth
Re: 2nd ordrer Butterworth vs 3rd order Butterworth [message #37923 is a reply to message #37901] Wed, 21 August 2002 06:43 Go to previous messageGo to previous message
spkrman57
Wayne,
Thanks, You pretty much told me what I need to know. I am guessing that using the 2nd order BW's I can use the same attenuation values for the 2nd order as the 3rd BW's. I am working on a project with JBL 2226J and Altec 288C(loaded with 16 ohm "G" diaphram) into 311-60 horns(they are aquaplas coated and don't ring like 511/811's). For 2nd order BW's @ 600hz, I have following info: 6mh and 12ufd, I am figuring 115db horn - 97db woofer = 18 db attenuation. I have not yet considered the cap for compensation yet as I want to hear the system straight up first. (breadboarding at this point) I wish JBL had included the le for the 2226J on their sheet/for 4 ohm .92mh/for 8 ohm 1.75mh and 16 ohm was omitted. I looked at your site for this info. I am guessing around 3mh might be figure. I need for zoebel/cap and resistor. would appreciate if you could derive this info for me.
Thanks, Ron
Previous Topic: 2 Pi Piezo Tweeter Choices
Next Topic: eminence psd-2002 vs selenium d300ti
Current Time: Wed Oct 21 00:30:34 CDT 2026
