Home » Sponsored » Pi Speakers » T-nuts question
T-nuts question [message #37847] Sat, 17 August 2002 07:53 Go to previous message
bqc is currently offline  bqc
How do you fasten the T-nuts to the baffle? Once you drill a hole
for it, do you just drive it in and sink the metal tabs into the
MDF and hope that the MDF will continue to grab them for years to
come, or do you put some liquid nail into the hole before driving
the T-nut into it to make sure the T-nut will never come loose.
Previous Topic: insulation thickness
Next Topic: kilomax vs. Magnum HO
Current Time: Fri Nov 27 04:08:40 CST 2026
