Home » Sponsored » Pi Speakers » converting port size
Re: converting port size [message #37839 is a reply to message #37833] Fri, 16 August 2002 13:29 Go to previous message
A 6" diameter port would be perfect - Make it 10" long. But the trouble is that you can't fit this port in the cabinet; It's a tight squeeze.
Then again, if the compression horn is mounted externally, you might not have any trouble fitting the 6" round port. And I know how you like to put those cool wood horns on top of the cabinets!
Previous Topic: theater four pi's finished (longish)
Next Topic: ZMAX How ?
Current Time: Thu Nov 26 09:50:33 CST 2026
