Home » Sponsored » Pi Speakers » 2 Pi's and the 20 watt resistor
Re: 2 Pi's and the 20 watt resistor [message #37598 is a reply to message #37596] Thu, 01 August 2002 07:14 Go to previous messageGo to previous message
spkrman57
Edwin,
I believe that is a "20 ohm" resistor, and it is used to stabalize the impeadance when used with a low powered tube amp that is sensitive to load impeadance. Also, that 20 ohms will not drain enough wattage to effect your amps output. I hope I gave you the right skinny!
Capt Ron
Previous Topic: Need Math help
Next Topic: Active crossover for 4Pi with 2235 Pi sub
Current Time: Thu Nov 12 00:25:10 CST 2026
