Wayne Parham Messages: 19105 Registered: January 2001
Calculating the compensation circuit is not always easy. Your tweeter circuit is perfect, and that's what I would use too. For a 12dB compensation circuit, use R1=50, R2=30 and C1=0.47uF. That will give you exactly the same tweeter response curve as the π 1K6a012dB crossover for 8 ohm drivers. If you want augmentation to begin sooner and be fully there by 15kHz, you might substitute a 1.0uF capacitor for the 0.47uF value at C1.
