Home » Sponsored » Pi Speakers » altec gear in a pi box??
Re: altec gear in a pi box?? [message #37530 is a reply to message #37503] Fri, 26 July 2002 15:58 Go to previous messageGo to previous message
EZ_Angus is currently offline  EZ_Angus
Hey Wayne: thanks very much for the info
>PiAlignments for that motor specify a cabinet of 8.5 cubic feet
>tuned to 30Hz. It further recommends a rectangular port having
>inside dimensions of 6" x 10.5" and 14" long. The response is nice
>and flat, with a -3dB point of 40Hz and -10dB at 23Hz. This is a
>very nice speaker with very full bass.
that would be a perfect lf set up 4 me. can you suggest somewhere where I could read about what it means to "tune" a cab to a particular frequency? Also, are there theories about how to allocate the 8.5 CF between width, heigth, and depth? Also, can you tell from pi align the upper -3db point (in relation to the 500 v 800 xover issue)?
>Some call this a line-level passive crossover, since the filter is
>passive.
so with this method, does each amp still only get fed the range its supposed to reproduce and see directly its driver on the other end?
>Let's get together sometime soon. Next time I'm headed towards the
>city, I'll drop you a line. If you come this way, you might do the
>same.
I would like that very much. my email is angus@ou.edu
Kevin aka EZ Angus
Previous Topic: Anyone need a JBL 4648A-8 or some 2226J woofers, contact me off list
Next Topic: replacing mid range speaker
Current Time: Mon Oct 05 04:09:42 CDT 2026
