Home » Sponsored » Pi Speakers » One Pi with sub in one cabinet (ie: 3-way)
Re: One Pi with sub in one cabinet (ie: 3-way) [message #37521 is a reply to message #37472] Fri, 26 July 2002 08:03 Go to previous messageGo to previous message
spkrman57
Wayne,
I ordered a pair of KSN-1038A's from Parts Express only to find out when I received shipment they are out of them. Okay, so I saved $8.50 per piezo by not having them. Was disappointed, I have a lot of misc piezo's and wanted to try out the one you use in 1 and 2 Pi's. I did not know that the 2105's reached up to 10Khz, that being the case, is that why you used the KSN 1041's instead of the ksn 1038's????? I know the Alpha 8's are good to 5khz, so I will try the system breadboarded and see what happens, I will post the results for the curious ones here.
I have another question, when I pruchase coils from parts express, they alway come out a little low in measured value, but the coils with the iron cores come out in the high end measured out. I just got two .7mh 14 guage and they come out the closest (of the others I have bought there in the past) as far as the air cores go (.683mh if I bend wires totally in coil, will go to .685mh) I finally got some 8 ohm 2226's (I already had 2226J's - 16 ohm) I am going to try and properly port the 3677 cabinets this time. Previously I removed the foam from the two 3" ports and they played pretty well (the 2226J's that is). Thanks, Capt Ron
Previous Topic: By-passing Caps: What Did I Do? Wayne?
Next Topic: fibreglass insulation oops
Current Time: Tue Nov 03 09:28:59 CST 2026
