Home » Sponsored » Pi Speakers » Difference between reciever and shelf system =
Difference between reciever and shelf system = [message #37402] Sat, 20 July 2002 13:58 Go to previous message
Jerry Parker is currently offline  Jerry Parker
Power output. Today I hooked up an old Sony shelf system unit to my main speakers that were being powered by a Technics reciever. I played several cds with great dynamic range such as the Telarc sampler. I also played a contemporary acoustic rock group, Days of the New. I have found their cd touch peel and stand sounds great.
I could not notice a difference between the two, the receiver and the shelf system that is, at low listening volumes. Once I turned it up, however, obvious things happened. The noise floor of the shelf system became audible, and I could hear the output compressing when played loud. This is probably due to the fact that the unit probably puts out less than 2w per channel. But other than that, I could tell no difference. I realize this was a subjective test, so later tonight I will have a friend switch between the reciver and shelf system several times blind test, to see if I can truely tell a difference.
What do you all think of this test? Wayne? The two should sound the same shouldnt they? The only reason one needs an expensive amplifier is for high power output, right?
Previous Topic: Horn loaded midbass?
Next Topic: Anybody remember the "Cyclops" race car from Road&Track?
Current Time: Fri Oct 16 01:58:22 CDT 2026
