Home » Sponsored » Pi Speakers » Passive Active Midrange Blah Blah ( long)
Filter Q [message #37391 is a reply to message #37389] Fri, 19 July 2002 08:13 Go to previous messageGo to previous message
I think a lot of guys have run active and been pleased with their results. The thing that is most important is using a crossover that has CD compensation. This provides 6dB/octave boost.
The passive filter in the π crossover goes one step further. It provides an initial shelf of flat response up to about 4kHz. Only after that point does 6dB/octave augmentation start. This is important because the goal is to conjugate the driver's power response, which is flat up to 4kHz mass rolloff, where it begins to droop by 6dB/octave.
The way it works is this: The (R1/R2/C1) compensation circuit acts as a damper for the tweeter's (L1/C2/C3) crossover filter, and sets filter Q. Without those components - as if the load were purely resistive - the output of the compensation circuit would be a nearly straight diagonal line of rising response.
Resistor R1 sets the Q of the L1/C2/C3 filter to be just slightly peaked, enough to raise output at the crossover frequency so that the response curve isn't a diagonal line there. It is lifted so that the first couple of octaves are flat, and then only after that does the response curve begin to rise 6dB/octave. This is discussed in the π crossover document, and the resulting response curves are shown.
Certainly this can be implemented in an active filter too. I'm sure some of them already do this, but I know some don't. When in question, it might be good to check and see.
Previous Topic: 3 and 4 way crossover
Next Topic: Brief review of 2 Pi's
Current Time: Sat Oct 17 19:09:24 CDT 2026
