Home » Sponsored » Pi Speakers » Just bought pre-cut MDF for my One Pi speakers!
Re: Port stuff [message #37376 is a reply to message #37375] Thu, 18 July 2002 11:50 Go to previous messageGo to previous message
Erik Johansson is currently offline  Erik Johansson
We'll see what I'll do then. As I said, I can get 59.2mm ID grey PVC tubes. That's only about 1mm off (I could make the port something like 2mm shorter, hehe) and now that I got the tips from you about the veneering I feel that it might be the right way to do it. Is the inside of the port painted black before or after the veneer is applied and trimmed around the hole?
/Erik
Previous Topic: Sensitivity ratings for Delta 15 etc
Next Topic: wall lining in two Pis
Current Time: Mon Oct 19 16:27:16 CDT 2026
