Home » Sponsored » Pi Speakers » Building a pair of 2 Pi in solid pine?
Re: Tolerance [message #37312 is a reply to message #37302] Mon, 15 July 2002 10:04 Go to previous messageGo to previous message
Erik Johansson is currently offline  Erik Johansson
Here is a picture of the ports I will be using. As you can see it's outer edge will extend about 2.5mm from the baffle (if I don't recess it which I don't have the tools to do) due to the flange with the screw holes. From where do I measure the length of the port? From where it starts (2.5mm out from the front baffle) or from the outside of the baffle?
/Erik
Previous Topic: T/S on the JBL 115H woofer
Next Topic: Wayne or anybody: L-pad values
Current Time: Fri Oct 16 17:46:00 CDT 2026
