Home » Sponsored » Pi Speakers » Veneering isn't so bad. Listen up!
Re: dont use the latex [message #37288 is a reply to message #37284] Sat, 13 July 2002 18:17 Go to previous message
The flamable brain cell killing glue is better. plain and simple.
The latex was developed to save the planet along with all the other latex and low voc products. A lot of "better for you" products are better than the one they replaced. in this case and especially for veneering, you want to use the solvent based glue. Do use it in a well ventalated area. outside as long as debrise wont fly into the glue line is great this time of year. Veneering is time consuming among other things. just not worth it to spend that much time and have the glue line fail after a short time.
Bill
Previous Topic: Crown (and other) amp power ratings
Next Topic: 1 Pi Plans
Current Time: Fri Nov 20 14:06:57 CST 2026
