Home » Sponsored » Pi Speakers » Crown (and other) amp power ratings
Re: Crown (and other) amp power ratings [message #37286 is a reply to message #37274] Sat, 13 July 2002 12:26 Go to previous message
fatkick is currently offline  fatkick
When you take a Macro-Tech 3600 or 5000 out of the box you will see that it is wired with a 30a plug on it and comes with the correct receptical to wire into your distro or wall box. Just make sure you have at least 10ga wire running from the breaker.
Previous Topic: Hi Wayne: Mounting drivers
Next Topic: Veneering isn't so bad. Listen up!
Current Time: Fri Nov 20 14:52:56 CST 2026
