Home » Sponsored » Pi Speakers » Veneering isn't so bad. Listen up!
Re: Hide glue. Really, really long! [message #37284 is a reply to message #37280] Sat, 13 July 2002 06:39 Go to previous messageGo to previous message
Neo is currently offline  Neo
Thanks for all the info.
I've got the paper backed veneer, so I guess I'll go with the contact cement. The Formica company makes a water based cement that doesn't seem to have as many leathal warnings... my be I'll try that. Have you heard about that? I got it at Lowe's it's called 160 Water Base Adhesive. The directions are the same as the contact cement, but you need to wait 30-40 minutes to dry.
Thanks again for your help...
Tom
Previous Topic: Crown (and other) amp power ratings
Next Topic: 1 Pi Plans
Current Time: Fri Nov 20 14:07:02 CST 2026
