Home » Sponsored » Pi Speakers » Wayne - Theater 4 Pi question
Re: Wayne - Theater 4 Pi question [message #37278 is a reply to message #37276] Fri, 12 July 2002 14:46 Go to previous messageGo to previous message
Overdamping the inside of your enclosure could partially be the problem with the lack of lower midbass and bass output.
Lining your enclosure walls with damping material and stuffing the box with polyfill will only hurt the response of a ported box woofer. You really only need it for damping high frequency output and cleaning up the midrange/upper midbass a bit. Unfortunately, you might have to strike a compromise between these two.
JMO.
Adam
Previous Topic: Any pi lovers in Australia?
Next Topic: T/S on the JBL 115H woofer
Current Time: Fri Oct 16 15:29:31 CDT 2026
