Home » Sponsored » Pi Speakers » For corner horn lovers. Just a chuckle.
For corner horn lovers. Just a chuckle. [message #37264] Thu, 11 July 2002 13:15 Go to previous message
Rider is currently offline  Rider
Copied from the High Efficiency Forum. Had to LAUGH !!! Just in case someone else finds it funny......
Posted by BrownTim on June 02, 2000 at 06:35:57:
In Reply to: Mr. Tom Brennan and all fans of the Horned Speaker, some questions about your speakers... posted by AudioHappy on May 31, 2000 at 21:40:04:
I can tell a good horn loaded system from the next room, or even through a wall. This is obviously not due to imaging (although a good horn system can have good imaging) It's dynamic range free of distortion. The corner loaded Klipschorn bass response transcends simple frequency response. It makes a big wavefront that direct radiators are incapapable of. Richard Greiner once described the bass of a Klipschorn as "rolling across the room and you can pat it on the head as it goes by".
Previous Topic: 4 PI Professional series.
Next Topic: Hi Wayne: Mounting drivers
Current Time: Tue Oct 06 21:06:01 CDT 2026
