Home » Sponsored » Pi Speakers » double bass in stage series
double bass in stage series [message #37152] Wed, 03 July 2002 15:43 Go to previous message
djstan is currently offline  djstan
Most of the speakers I build are used in my portable dj business.
Seems you can never have too much bottom end. What I was thinking is building a pi 4 with the omega 15inch/2002 eminence and adding a second omega in the same cabinet. I'm thinking that the second woofer would be crossed below the midrange band for just the bottom end, otherwise there would be too much mid for the horn/mid balance. Would the cabinet size be doubled? Can I use the same crossover design with with zobel. What would you suggest as low to mid crossover frequency. Not wanting to use the Omega 18 inch because of the cabinet size. Thanks
Previous Topic: Beta 12 isobaric sub.....
Next Topic: Happy 4th of July!
Current Time: Tue Nov 17 12:56:38 CST 2026
