Home » Sponsored » Pi Speakers » Piezo chirping
continued.... [message #37130 is a reply to message #37129] Tue, 02 July 2002 01:43 Go to previous messageGo to previous message
dbeardsl is currently offline  dbeardsl
>I've run into this before. If the amplifier can't damp the system
>well enough, back EMF causes the tweeters to oscillate - making that
>chirping sound. I've found it to be the case with woofers having
>high inductance voice coils, even on amplifiers with good damping
>ability.
yeah, I just didn't think it'd happen with the Alpha's.
>Try connecting the woofers in series, so that load resistance is
>raised. This will also raise inductance, but since these woofers are
>known to work well with piezos in most cases, you may find a
>solution in this.
He is really going for max output, so parallel to series is a 6db hit.. final resort, if it even helps.
>You could also use a single compression driver to replace the
>piezo's, if no other solutions are found.
The cabinet is already built, no room for a compression driver, really.
Hmm... how about a second order low pass right when the piezos come in around 4k?
I read all of the previous posts about it... good info. I hope I find a solution.
Previous Topic: Instrument cabinet questions
Next Topic: Bass cabinet recomendations - need tips
Current Time: Sat Nov 07 12:12:02 CST 2026
