Home » Sponsored » Pi Speakers » Isobaric with a pair of Eminenece Beta 15's.
Re: Isobaric with a pair of Eminenece Beta 15's. [message #37116 is a reply to message #37114] Sun, 30 June 2002 14:21 Go to previous messageGo to previous message
Should play fairly loud, but the box peaks nearly 5db at 62 hz.
I don't know what they cost, but I imagine you could get a single Kappa 15lf for the price of two of the betas. Run it five cubes (140 litres) tuned to 40 Hz with a pair of 4" ports. You'll get great output, and this thing goes damn *low* all things considering... To me it sounds flat to 30 Hz almost. It's one of the best low frequency drivers I have found from eminence that isn't too pricey and will run in a pretty small box.
You'll get more output than the betas (same sensitivity, but no power compression) with flat response, good sound and surprisingly deep bass.
Adam
Previous Topic: Passive Radiator versus Port
Next Topic: plans for studio 2 pi
Current Time: Tue Nov 03 13:21:47 CST 2026
