Home » Sponsored » Pi Speakers » 8-ohm, 90dB/W/m sub recommendation?
Re: 8-ohm, 90dB/W/m sub recommendation? [message #37024 is a reply to message #36989] Thu, 20 June 2002 18:00 Go to previous message
Jerry Parker is currently offline  Jerry Parker
Well, I like Wayne's response, and that would be what I would go with, but the boxes for those drivers would be kinda big, and they are very effiecient too. Sounds like more than you need for your speakers. You could try the Dayton Titanic, it has a very very low fs, and goes very low in frequency in a sealed enclosure. It is not designed for ported boxes, nor will it go very loud. http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=6639445&St=1461&St2=-54538287&St3=78881025&DS_ID=3&Product_ID=7773&DID=7 It is, however regarded to sound Very good. It only needs a 3cuft enclosure too. If you want an extremely tiny enclosure you could get a http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=6639445&St=1461&St2=-54538287&St3=78881025&DS_ID=3&Product_ID=7764&DID=7 Dayton dvc 12" too. It works well in a 1.2cuft sealed box, but the bass in a room wont go much lower than 30hz, and anechoic its around 40hz.
Previous Topic: CTS piezo w/ Eminence Beta coax?
Next Topic: Plans for 4pi professional series
Current Time: Mon Oct 26 03:55:12 CDT 2026
