Home » Sponsored » Pi Speakers » Reduce lenght of a JBL 2397?
re:2397 horns [message #36926 is a reply to message #36920] Mon, 17 June 2002 09:28 Go to previous message
TimG is currently offline  TimG
If you don't like your 2397 horns I would sell them on ebay, or hold onto them, as the old JBL stuff only seems to increase in value. They regularly sell for $500 a pair on ebay. Then you could buy yourself some horns more suitable for your cabinets or build yourself a pair of the correct size out of plywood. Once you modify the 2397 horns they will have no resale value, and if they dont work out you will be out a set of horns and $500.
Previous Topic: Info on buying and using a woodworking router?
Next Topic: Anyone want to trade a pair of 2226H for my pair of 2226J?
Current Time: Sat Nov 07 07:33:57 CST 2026
