Home » Sponsored » Pi Speakers » Small problem regarding Motorola:s KSN 1038
Re: Wohoo ! =) it is the one ! [message #36847 is a reply to message #36841] Wed, 12 June 2002 07:31 Go to previous message
Mattias S is currently offline  Mattias S
Spoke with one of the technical staff at Monacor - Sweden. The tweeter is identical. I don't know if its an oem production or if they are retailers but it is indeed the same drivers =)
Note: Just in case someone is interested. 2 drivers ( cant remember wich ones ) are altered from the original design from motorola.
I also learned that retailers of motorola piezotweeters usually rename the product to fit their own purpose, hence the same drivers have lots of different names.
So for all you Swedes wanting to build 1 Pi or 2 Pi:s check with www.monacor.se for the KSN-1038.
Regards // Mattias S - Sweden
Previous Topic: Cone Stiffness!
Next Topic: crossover caps...
Current Time: Thu Nov 05 22:56:35 CST 2026
